2014 Double Slider Sprinter Van
One of the things the client wanted was a light bar. A quick look at the area the light bar will need lets us know we should wait to put it on after the front fan is installed.
On to the fan install. We use butyl tape tape and another sealant then a sealing tape to prevent any leaks. Overkill but its worth it.
Next up we add the Dometic RTX 2000 12 volt AC unit. This AC is super efficient and our go to unit for the 144 wheel base Sprinters.
Next up Abel starts working on the Espar S2-D2L diesel heater that will be located under the passenger seat.
The fuel pump will be located under the van and draw diesel from a factory fitting that Mercedes puts on the diesel tank. Thanks Mercedes!
