2019 Sprinter 144 Basic Build
Daniel
Staff Member
With the opening of our new shop we welcomed in a white 144 Wheel Base Sprinter. After going over the basics of the build once more with our client she left her van in our hands to build out her dream weekend explorer. She also plans to use it on longer trips as well in the future so we are adding in a few things that will make those longer trips better.
The first thing I did is remove the seats to access the two areas we will be adding the auxiliary battery and components.
Important: Before removing the seats you MUST disconnect the power to the vehicle. If you do not do this first you take a chance of throwing an code and you would have to use an OBD to clear it or take it to dealer and pay to clear the code.
There is a power disconnect post located behind the lower dash panel. Remove the front floor pieces to access the screws holding lower dash. You can then depress the connector to disconnect the power.
Note: Remove fuse #32 from the fuse panel located in the driver seat base as it will continue to power ignition by the emergency backup battery.
You can now disconnect the power to the seats.
Each seat has four bolts, use a torx bit to remove them.
The drivers side seat has the power distribution and other wiring under it. We will connect to an empty slot on the power buss for the Victron Energy Orion-Tr Smart DC/DC charger.
Fitting some of the main components under the passenger team really takes some thought on functionality. The Victron Phoenix 12/1200 is pretty large so we will create a base mount with an open channel under it for better air flow/cooling.
I fabricated up an aluminum plate for the seat base that will allow the access to the Blue Sea battery on/off switch. I will clean this up and paint it in a matte black paint.
I fabricated a cover that will only expose the on/off switch. Once removed you can then access more parts of the system. I will paint this cover a rough matte black.
With the panel open you can access the auxiliary fuse panel.
More electrical today, I pretty much finished building mounts and a wire chase for the wiring that will be under the passenger and driver seats.
Time to get the interior panels out and get some things on the roof installed.
One thing about the van wiring is that Mercedes puts the wiring to the rear tail lights, interior lights and backup camera just attached to the outside of the interior walls with little protection for the wiring. I will pull the full rear wiring harness and add wire loom to it and relocate into the interior of the walls to give it a bit more protection before putting the walls up. We will be doing birch walls for this interior.
First fan roof hole cut, the client later decided to add two fans so we will cut a second one as well.
We source our solar panel cross bars from Impact products and love how clean and easy their parts for the panels install. Everything labeled and even a sample is sent assembled.
Next up I will make some mounts for some exterior Rigid Scene lights that the client can turn on to light up her camp spot.
Testing the light mount and angle, after the initial look I decided to make the mounts a bit taller.
Next up is the bed platform made from steel bed rails and aluminum cross members to save a bit of weight.
(Note: UPDATE post is from 2021 and We now in 2023 build fully TIG welded modules)
I used a piece of wood the same thickness as the wall panels to make sure there is enough clearance once installed.
The locations for the rails are spaced so that two sections of 3/4" birch can be used and spaced accordingly.
Rails and cross members are installed using plus nuts put in with a pneumatic tool.
I use rivnuts for basic mounts but I choose to use Plus Nuts for things that need to hold more weight.
Test fitting of all the rails and making sure it is level.
I made the rear most bed panel top angled to follow the curve of the rear doors and corners of the van to get the most out of the space possible.
Another test fit and level to double check.
All good so now I will disassemble and get the pieces painted.
